Valve Stem leaking
Old Feb 26, 2006 | 10:10 AM
kaptap's Avatar
Default Valve Stem leaking
The valve stem on my front tire is leaking as soon as I loosen the cap. Can I replace the valve stem myself or does it require special tools? If I can do this, can you provide instructions? Thanks.
Old Feb 26, 2006 | 03:54 PM
Bear4570's Avatar
First try tightening the valve core. If that does work, replace the valve core. Then do a valve stem, as you have to pop the bead loose on the rim and that is not fun. Chances are the core is loose or bad. Walmart or an auto parts store have valve stem kits that have cores and a tool included.
Old Feb 28, 2006 | 08:52 PM
kaptap's Avatar
THANKS Bear!!! I replaced the valve core and no more leak. Grand total to fix was $2.98 and two minutes of my time.
Dammar
Apr 20, 2016 06:03 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
