05 500 fuel leak????
Old Feb 26, 2006 | 09:58 PM
Gercks's Avatar
Default 05 500 fuel leak????
2005 Arctic Cat 500 4x4 Fuel leaking from bowl drain (drain screw is tight ,does drain when loosed ,stops when tightened) Fuel only leaks when engine is running, stops when engine is turned off. If I place my finger on carb to block off fuel the engine will stall. Thanks for all your help.....
Old Feb 26, 2006 | 10:03 PM
Bear4570's Avatar
You need to check the float level. If it is too high it will slop over into the drain thru the vent at the top of the bowl.
randymack
Aug 24, 2015 05:47 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Unzzy66
Jul 11, 2015 10:01 PM
