05 450R GEARING
Old Feb 28, 2006 | 10:19 AM
z4hundo's Avatar
Default 05 450R GEARING
I have had my 05 450r for about 2 months. It is the best quad i have owned, but I do have one complaint. First gear seems really high, and in the tight technical stuff where i ride, it seems to want to stall out. What can I do with the gearing to make it a little more "woods friendly"?
Old Feb 28, 2006 | 10:35 AM
SFA's Avatar
SFA
A smaller front sprocket would do the trick, as would a larger rear sprocket. This will lower your speed in all gears though so going too low will really hurt your top end. Try one tooth at a time on the front sprocket and see how you like it. I'm not sure how many teeth are on the front sprocket on the 450 but I would never run any less than 13 teeth, just my opinion.
Old Feb 28, 2006 | 10:45 AM
quad2xtreme's Avatar
Stock gearing on the 2005 is 14/38. The 2006 runs 13/38 (of course the tranny ratios are different).
I agree with trying dropping to a 13 on the front. At 8000 RPM, your max speed is 66.5 MPH with a 14 tooth front. With a 13, it will be 61.7 MPH.
/Jon
vandammages@gmail.com
Aug 20, 2020 11:50 AM
bigbear350quad
Sep 11, 2015 12:40 PM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
