fix recon
Old Mar 4, 2006 | 08:34 PM
reconriderman's Avatar
Default fix recon
how do u fix a 4-wheeler when it poat like it is not geting any gas?
Old Mar 4, 2006 | 11:19 PM
Default fix recon
is it the carbarater
Old Mar 4, 2006 | 11:32 PM
1988TRX250R's Avatar
Default fix recon
Define poat for me. Just giving you a hard time, don't sweat it. What are you experiencing that you think your not getting any fuel? Does it seem like its running out of fuel, are you opening the drain screw on the float bowl and nothings coming out, what? The more info the better to help you w/ your problem.
I feel like I'm at work and the work order says "don't start". Does it crank but not start, does the solenoid just click, when did it run last and how good did it run? More information makes my job a lot easier.
Old Mar 4, 2006 | 11:41 PM
squeege's Avatar
Default fix recon
pull the spark plug out and drop some gas in the spark plug hole maybe use a straw full holding your finger on the end of the straw. Put the plug back in connect it then start it. What happens?
Hunter100us
Oct 7, 2015 11:46 PM
peytonius
Sep 28, 2015 02:18 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Hondamx751
Aug 13, 2015 01:06 AM
MNatv89
Aug 10, 2015 02:20 PM
