450 es shift problem
Old Mar 5, 2006 | 07:35 PM
rudy24's Avatar
Default 450 es shift problem
2002 450 es will shift to first and reverse but will not go to second,third ,fourth,fifth. checked for codes ,none found if i check right
Old Mar 5, 2006 | 07:42 PM
hondabuster's Avatar
Once the motor is warm...does it shift ok then?
How long has it been since the clutch adjustment was made?
Hows the oil level and condition?
Old Mar 5, 2006 | 08:11 PM
rudy24's Avatar
shifts the same hot or cold , just change oil & filter ,no differce
Old Mar 5, 2006 | 09:19 PM
Try the clutch adjustment.
Theres a nut and slotted screw on forward side of motor, in the middle of the round shaped cover. Warm the motor, and then turn it off. Lossen the lock nut a turn or two, then with a screw driver, go ccw on the slotted screw, until you feel increased resistance. From there, back off (cw) 1/4 turn and hold the screw while snugging the lock nut.
Old Mar 8, 2006 | 07:28 PM
1988TRX250R's Avatar
Try shifting w/ the manual shift tool. If it shifts fine w/ the tool, your problem is electrical. If it still doesn't shift, you have a mechanical issue.
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
