how to make 06 trx90 faster
Old Mar 5, 2006 | 08:15 PM
trxfourfiftyr's Avatar
Default how to make 06 trx90 faster
How can you make the new trx 90 faster with out adding on to the engine. (like pipes,air filters ect.)
Old Mar 5, 2006 | 10:23 PM
SFA's Avatar
SFA
Sorry to say but your pretty much stuck with what you got. Sure you can throw money into a pipe and a filter but your really not gonna gain much out of that, not enough to justify the cost imo.
Old Mar 5, 2006 | 10:31 PM
fixitman69's Avatar
A trx90 isn't meant to be fast. If you need more power and more speed, it's time to step up to like a 250ex
Old Mar 6, 2006 | 09:46 PM
I Have a 2005 450r I just bought the 90 so i can screw around im my yard because i can only get into second gear in my yard with my 450 I only have one acre, and i have a crf 50 that has a 88cc kit in it and a "5" inch fork and Rear shock and it flys. I just talked to a guy today that told me how to make it faster with out adding any thing to the engine. I guess you have to snip a pink wire comming out of the engine case and it it is the 4th gear speed restrictor and he said it makes it go alot faster. And last night i ordered a big gun exhaust and a k&n air filter.
Thanks for your help though!
Old Jul 27, 2006 | 09:25 PM
Irunwire's Avatar
You definetly need to cut the pink wire or remove it from the electrical connector so that it can be reconnected later(if need be). I took the air box lid off and dropped the rear sprocket 2 teeth and it made it a lot quicker with very little loss to low end. Hope this helps.
Old Jul 28, 2006 | 12:41 AM
crazy90's Avatar
would a 1994 have the same wire
Old Jul 28, 2006 | 02:35 PM
crazy90's Avatar
i sniped the pink wire on mine and took my air box lid off and it ran a whole lot faster i got a big gun exhaust coming in a day or two so hopefully that will help to. Thanks for that advise you put on there.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Backwoods_badass
Aug 3, 2015 01:34 AM
HondaR24
Jul 16, 2015 10:45 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
