unplugging kebc
Old Mar 8, 2006 | 09:55 AM
Ren's Avatar
Ren
Default unplugging kebc
I think I may be having a bit of trouble with my KEBC. I read in some threads that you can remove it without damage to bike while opperating. I noticed that there is a 5pin connector on the KEBC. So if I just unplug it and seal the ends I should get the same result as removing it, right? Before I do this I would like some input on the issue. I realise that the engine brake will not work, but I heard that I may gain a little top end speed. By gaining top end speed will i lose bottom end power? Any info appreciated. Thanks Rendell.
Old Mar 8, 2006 | 10:48 AM
Uinthas's Avatar
You wont have engine braking if you just unplug the KEBC, but you'll have your 4wd light flashing & that get's anoying.. If you want to remove it & gain some top end you should remove the braking fork, you do that by removing your belt cover & then remove the actuator, and then the fork, it's real simple just 8 bolts on the cover 3 on the actuator & then the fork requires a circlip tool. I'd recomend removing the fork & then re-installing the actuator so you dont have flashing lights, thats also what suppose to give you another 1-2 mph top end is removing the fork...
Old Mar 8, 2006 | 07:06 PM
alwaysride's Avatar
Yes, Just remove your fork. Such a simple mod which can be done in 10 mins.
Old Mar 8, 2006 | 11:49 PM
Uinthas's Avatar
Did you notice any difference with your fork removed alwaysride?
Old Mar 9, 2006 | 12:05 AM
alwaysride's Avatar
Yes i did, I felt to me like i just had a tad bit more power like the clutch wasnt being held back like it used to. Im glad i did it. Only took 10 mins.
95wolv
Sep 27, 2024 12:00 PM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
