chain on 300ex
Old Mar 8, 2006 | 02:09 PM
Atvstevo1337's Avatar
Default chain on 300ex
How do i tighten the chain on a 300ex? it's around a 2001 i think
Old Mar 8, 2006 | 02:12 PM
HondaMan440ex's Avatar
Losen the Allen bolts onthe swing arm, and the other bolt that right below the allen bolts. i believe there is only three total you need to losen (going of memory) once the bolts are lose, just stick an allen wrench in the slots by the sprocket and pull towards you i belive. this should tighten your chain. be sure you retorque the bolts as they will come lose if not tight enough. PM me if ya need more instructions.
Old Mar 8, 2006 | 07:14 PM
HondaRider12's Avatar
thats right except theres only 2 allen bolts one on the left one on the right
Old Mar 8, 2006 | 07:20 PM
only problem is my right bolt is completely jammed.. my left one was completely out and i still couldent ajust it. i sprayed some WD40 on the bolt but it dident help, any ideas?
Old Mar 8, 2006 | 10:17 PM
YFZracer12's Avatar
Try using an impact driver on that bolt and i would be getting another bolt for the other side
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
