front or rear diff problems
Old Mar 13, 2006 | 03:21 AM
Wildcountry's Avatar
Default front or rear diff problems
I am new to this site and need help!!! I have a bf 750 and about a month ago i over turn it upside down in some water. Of course i flushed out the engine about 4 or five times and changed filters. Every thing was going good but than the tubes that come out form under the handle bars started spitting out a milky fluid. Come to find out that was from the diff (after taking to dealer) He flushed out the front and rear diff and rerouted the hoses so that they were faceing down (so not to spitt on you while riding down the road) but i noticed the other day after riding a couple of hours that i still had some milky substances coming form that tubes what can i do to get all the water out. and how can i do it Much thanks
Old Mar 13, 2006 | 12:41 PM
Hayashi's Avatar
If that is really diff oil/water mixture coming out as your dealer says, then you should flush the diff gear cases again since they still got some water in it. Each diff gear case oil drain bolt, just drain and refill with CORRECT type oil, ride for a little while, drain and refill again to make sure you drain all the water out. Also, you blow out the diff gear case vent tube (that is where the oil/water spraying out on you) with compressed air to get any remaining water out.
bucklove007
Jun 8, 2015 07:28 PM
cornermike
May 27, 2015 10:04 PM
ragewraps
May 27, 2015 08:07 AM
Code54
Jun 26, 2000 01:57 PM
