Super trapp pipe on now it fouls plugs
Old Nov 13, 2000 | 07:58 PM
94DGblaster's Avatar
well i put my super trap pipe on tonight, haven't did the uni..
tried 4 and 8 disk. It just fouls plugs...i was using an old plug from when it was new...so maybe thats the problem
but anyways..i just turns them totally coal black.
whats going on!!
Old Nov 13, 2000 | 10:07 PM
HondaLuvr303's Avatar
Is it oily or, is it sooty?
Old Nov 13, 2000 | 10:29 PM
It was sooty. I wouldn't call it oily.
It sure seemed to me it was running rich, but that makes no sense to me...
Old Nov 14, 2000 | 02:40 AM
cartman308's Avatar
sounds like it needs rejeted...i can't tell ya if it needs to go up or down....but probably needs rejeted.
Old Nov 14, 2000 | 11:49 AM
trapperb1's Avatar
When you change exhust and air filter you should go up in main jet size, at least one or two for your mods. On my wife's old 300, with a Supertrapp and a K&N, I went up three. Ran great and never had a plug problem.
Old Nov 14, 2000 | 02:47 PM
snowshark's Avatar
Try going up two jet sizes & then check your plug. If still black go up one more if needed.
You might have to repeat this process if you install a high flow air filter such as uni or K&N.
Old Nov 14, 2000 | 03:40 PM
well yeah i figured i'd have to rejet..
but thought it would run lean not rich..
isn't black too much gas, and white too much air?
Old Nov 14, 2000 | 08:17 PM
ogre's Avatar
94DGblaster-
Did you jet like we talked about last week (go up on mains until it skips, then drop down one)? You didn't alter the needle position yet, have you?
Black soot represents a rich mixture. What main jet size do you have in now, and what main jet did you take out of the machine (stock jet).
Remember, make your modifications first (number of disks in pipe) - then jet to that. Don't adjust these variables (number of disks) while you jet, it just adds more complexity.
ogre
Old Nov 14, 2000 | 10:42 PM
yeah..
well i went to a 230(thats what the dealer told me to get) now it runs lean still with 8 disk.
So i am going to go up to a 240..
The plug was fouled before i put the pipe on a believe..
i noticed it missing sometimes..when i was riding.
bad jetting and a bad plug really added.
So i gotta go up..
it actually runs great as it is..but the plug is buring a little white..
Old Nov 19, 2000 | 01:54 AM
hondatrx300ex's Avatar
I had the same prob...... go get 2 new plugs..... problem solved.....you've actually be runnin lean then.....
scram5050
Aug 19, 2015 02:19 AM
erntee61
Aug 9, 2015 02:54 PM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
JohnnySplat
Aug 6, 2015 12:07 PM
cornermike
Jul 30, 2015 06:37 AM
