Recon Air Filter
Old Mar 14, 2006 | 05:52 PM
RABDAB's Avatar
Default Recon Air Filter
I'm looking at replacing the stock air filter on my sons 02 Recon, What one's are best ( White powerfilter, K&N, UNI, NO-TOIL, Twin Air ) and are they worth the money ? And what about cleaning ? Thanks
Old Mar 14, 2006 | 09:06 PM
LotusPosition's Avatar
If you decide to go with K/N, I have good used one for cheap.
Old Mar 15, 2006 | 12:44 AM
SFA's Avatar
SFA
I would stick with a good foam filter like the uni. They don't cost much and it's just a good idea to have good filter or to just have a spare so while your waiting for one to dry after cleaning you can pop on the other one and still ride. Cleaning a uni filter is the same as cleaning the stock foam filter.
Old Mar 15, 2006 | 07:30 AM
RABDAB's Avatar
What are you using to clean them ? It looks like if you go with K&N it can get pricey for the cleaner and treatment. I have been using kerosene on the stock one (probably not the best thing)
Old Mar 15, 2006 | 02:59 PM
SFA's Avatar
SFA
I have always used air filter cleaner, it comes in a aerosol can. But a lot of people use gas or kerosene. I have been told that it can break down the glue in the filter but I have yet to see that actually happen.
Old Mar 15, 2006 | 08:17 PM
recon99's Avatar
I'd go with a k&n, foam filters are a big mess and time consuming to clean. I had a k&n on my recon and don't have any complaints about it.
And k&n's expensive to clean? No way! It's like $10 for a recharge kit, that is good for at least 8 cleanings and re-oilings.
Old Mar 16, 2006 | 12:15 AM
bubba1969's Avatar
my local honda parts man recomended simple green.....have to say its safer and works great. i too asked myself this question k&n versus foam....i think im gonna stick with foam on my 05 recon i will just stick on a different pipe and rejet for a little extra go
Old Mar 16, 2006 | 08:16 AM
RABDAB's Avatar
I know how to clean the foam filters. But how do you cleah the K&N filters ?
Old Mar 16, 2006 | 02:08 PM
recon99's Avatar
The k&n recharge kits come with a spray bottle of cleaner, and either a squeeze bottle or aerosol can of oil. First you spray the cleaner all over the filter until it's saturated and let it soak for a few minutes, then you spray it off with a garden hose. Usually you don't have to, but sometimes you have to repeat this to get it clean. Then you just let it air dry, and re-oil it until the entire filter is red again. One of the things that make me feel more comfortable with the k&n filters is that the filter is white, and the oil has a red dye, so you can easily see if you missed a spot. I don't trust foam filters because I never know how much oil to put on, and if I have the entire filter covered with oil.
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Jason Campbell
Sep 7, 2015 02:25 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
