2000 Xplorer running rough
Old Nov 14, 2000 | 12:08 AM
wyomingwapati's Avatar
Recently bought a 2000 Xplorer 400 new from the dealer a few months ago. I had my dealer rejet it before I took it off the showroom floor, since I do all my riding at elevations between 5300-9000 ft. He put in a 185 jet, taking out the factory 195 jet. I though he should change the clutch weights also, but he advised against it. To date I have 300 miles on this quad, and have had to change out the plug 5 times now because it gets fouled. It doesnt seem to matter whether the air temp is cold or warm (have ridden it in 65 degrees weather and as low as -4 degrees Farenheit), I still foul plugs. It just isnt running smoothly, sputters alot. My question: Could it be the jetting? or is there a carburator adjustment I should look at?
Old Nov 14, 2000 | 03:29 AM
rotaris's Avatar
Had the same problem with my 95 explorer.Check alignment marks on oil pump may be running to rich.This was not my problem though.I put in 1 size smaller pilot jet and it cured my problem.Running too rich on bottom end or idle end.
Old Nov 14, 2000 | 01:28 PM
Bill.Ciliberti's Avatar
It sounds to me like your oil injection unit is pumping in to much oil and fouling out the plugs.Have the dealership check the alignment/adjustment of the cable,
Bill
Old Nov 14, 2000 | 05:17 PM
Thor's Avatar
Another thing to check would be the setting for the choke. A partially engaged choke caused by not enough slack in the choke cable line could also foul plugs.
SOLOLUCKY
Oct 4, 2024 09:09 PM
green giant
Jul 13, 2017 12:07 PM
wannabe32
Jul 7, 2015 11:30 AM
wbfjim
Jun 8, 2015 06:20 PM
cornermike
Jun 3, 2015 07:27 AM
