700 Raptor Slip-On
Old Mar 16, 2006 | 05:58 PM
Rodneyfx1's Avatar
Default 700 Raptor Slip-On
If I just put a slip-on pipe and nothing else on the 700 Raptor would I still need to get a efi controller? I asked my local Yamaha dealer and he said a slip on would be fine but if I went with a aftermarket air filter then I would need the controller. Has anyone tried this yet or have any info? Thanks.
Old Mar 16, 2006 | 07:30 PM
smuznu's Avatar
Yes, you will need an EFI controller. Your dealership is wrong!
Old Mar 17, 2006 | 11:32 AM
EvilErnie1's Avatar
In my experiance you can get away with removing the stock spark arrestor, or removing the air box lid...not both. i first started out by removing the spark arrestor and it ran better..did a plug check and it was still rich enough. then i put on the GYTR slip on...it ran just about the same just a little deeper in tone and a little better mid range. the best performance gain was from the power commander. i put that on about 2 days after i put on the slip on then removed the airbox lid. was a huge difference. the GYTR header made a good difference also when it was combined with the GYTR intake set up. But still the power commander beats all.....and its easy of use gets it an A+.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
