Carbs for 660 raptor
Old Mar 18, 2006 | 02:25 PM
Cubb's Avatar
Default Carbs for 660 raptor
Which is better the edelbrock or the keihin? And why?
Old Mar 20, 2006 | 01:04 AM
fizzak's Avatar
I know nothing of the Keihin but I took a loot at it, I assume you will have get 2 of those to replace the stock Mikunis?
Anyway I give a thumbs up to the Edelbrock, 2 years and not a problem. Install the carb and the bike starts right up without tuning. Ride for 30 minutes and check your plug for lean-rich conditions. Turn the dial at the top Right for rich Left for lean done. No more bogging on the whoops, no more stalling after a wide open run. No more choke, just fully pump the throttle 2-5 times if cold and you are running. I will be submitting a full tuning and mod guide for the Edelbrock on Raptortranny.com after I test some intake mods.
Old Mar 20, 2006 | 04:24 AM
Mr45auto's Avatar
What have you done to the engine?
I have a full build 686 and the stock carbs just couldnt feed the engine. I went with the FCR 35s to get the fuel delivery the engine needed. I doubt the edelbrock single could do it for a fuel hungry 686. If you're running a close to stock engine then the edelbrock will be tons cheaper than the FCRs. First off figure out if you really need new carbs or can tune the stockers adequately for your application.
The FCRs have no choke, it's a beotch to get it started and keep it running when it's below freezing. You've got to give the motor some decent warm up time and even that can be a challenge. It likes to stall alot before it gets warm. Warmer weather it's not an issue, it'll fire right up and a couple minutes of idle it's ready to roll.
Old Mar 21, 2006 | 01:53 AM
Cubb's Avatar
well i have an 05 raptor with curtis sparks exhaust..... pro flow kit...... 11 to 1 wiseco piston and stage 2 hot cams........any aditional info would be great
Old Mar 21, 2006 | 03:45 AM
Mr45auto's Avatar
First off is there a specific issue with your stock carbs you're trying to address? There's alot of tuning that can be done with the stockers. If you're as modded as you're planning to get then the Edelbrock will probably be able to feed it fine but I just dont see it providing adequate fuel flow if you go with a bigger bore and porting. I doubt the FCRs would be a major improvement if you're not having any specific issues and only looking for better performance. In my case I just couldnt get the midrange and top end dialed in and the biggest jets I could find still gave me a white plug. The FCRs move alot more fuel and gave me back both mid and top where the stockers would let me have one or the other and not both.
Old Mar 21, 2006 | 03:39 PM
Cubb's Avatar
so with the mods that i have stated up about are you saying that my stock carbs will be good?
Old Mar 21, 2006 | 03:40 PM
Cubb's Avatar
*above
Old Mar 21, 2006 | 07:44 PM
Mr45auto's Avatar
I'd stay with the stock carbs and try to get them dialed in. Your money would be better spent on porting or a billet clutch basket.
Old Mar 21, 2006 | 10:05 PM
oscar660's Avatar
i have heard stock carbs not flowing enough but i just cant see it, i got cam piston and a bunch of outher crap done to mine and i run alcohol , my mains are drilled out to 1/8 inch and it flows good so it will flow enough i can help u with ur jetting but i need to no everthing along with your alt
Old Mar 21, 2006 | 11:54 PM
Ernie660R's Avatar
I don't see why people start to drill jets when they first have to remember that the needle and seat inlet hole is about the size of a 175mj. So it does not matter what size your main jet is, its only going to get what can get in through the needle and seat. OH and not to forget once you have drilled the jets out now you run a risk of running lean on the top end and siezing up your piston to the cylinder, due to a lean condition.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
