After Market Air Filters?
Old Mar 18, 2006 | 10:09 PM
RancherATCrazy's Avatar
Default After Market Air Filters?
I have 2 05 Rancher AT's. What else do I have to do if I put in aftermarket Air Filter's? And what kind should i check out? I don't want the foam/oil filters anymore they are a pain in the ***.
Thanks
Old Mar 18, 2006 | 10:11 PM
polarismexican's Avatar
k&n should be wat ur lookin for, they have the best airfilter and a pretty oil filter.
Old Mar 18, 2006 | 10:21 PM
I was looking at the K&N but will the filter fit on my quad or do I have to buy the whole Air Filter Kit? Do I have to change my pilot screws or jets?
Old Mar 18, 2006 | 10:27 PM
ill find the size for ur fourwheeler, just give me a minute
Old Mar 18, 2006 | 10:29 PM
no u don't have to change anything, just put on, oil it and go
Old Mar 18, 2006 | 10:31 PM
one last thing wat size is ur engine, 400, 330 wat
Old Mar 18, 2006 | 10:56 PM
Boomer2's Avatar
Make sure you run an a outwear on the K&N. They flow more than foam but let more dirt through
Old Mar 18, 2006 | 11:00 PM
I am running a 400. Is there any filters out there that you don't have to oil? Do they make dry filters?
Old Mar 18, 2006 | 11:46 PM
nofearatv's Avatar
How do you oil a filter...just pour oil on the filter? Also whats an outwear?
Old Mar 19, 2006 | 09:35 AM
Boomer2's Avatar
If you have a foam filter you can use motor oil or a special oil. You pour it on the the filter then you kind of work the oil into the filter till it's saturated. I usually pour oil on the filter then put it in a big plastic bag to work the oil in the filter to avoid a mess. If you have a K&N filter they have special oil in a spray can that you just spray on the filter. A outerwear is a fabric skin that goes around the filter, some are waterproof, that acts as a prefilter. They are made by K&N or Outerwears
