Maintaining the 800 myself
Old Mar 22, 2006 | 01:41 AM
EasyQuader's Avatar
Default Maintaining the 800 myself
Is any one out there doing their own service work on the 800. I plan to do mine. Any tips or tricks? Like the O-ring on the filter cover and the oil plug gasket need to be replaced each time? Doing my own maintenance helps me bond with the machine.
Old Mar 22, 2006 | 10:30 AM
giverrr's Avatar
I plan on doing my 650 outty myself after the first service by the dealer so can't help you yet but I too will be listening for any tips.
Old Mar 22, 2006 | 10:50 AM
yjacket2001's Avatar
Wait until you need it, void warranty.
Old Mar 22, 2006 | 01:46 PM
wideopenrider's Avatar
Whats got more power, the outty 650 or the BF 650? And is there anything diffrent about the OUtty 650 or is it the same as the 400 and 800?
Old Mar 22, 2006 | 04:15 PM
giverrr's Avatar
The 650 is identical to the 800 except for displacement, all other features are the same, suspension, efi, dimensions etc. Have never drove the BF 650 so I cannot say which has more power. The Outty is strong, that I know.
Old Mar 22, 2006 | 08:35 PM
Daranello75's Avatar
650 weight more because it has steel wheels. The 800 has aluminum
Old Mar 22, 2006 | 10:02 PM
Ductape's Avatar
Don't need to do the O-ring each time nor the copper gasket on the drain plug. I would keep a spare O-ring around and change it once a year anyway.
Us a small wrench or socket on the forward most of the three filter cover bolts and then you won't need to remove any plastic.
Drain plug on the rear diff is hard to see. On the left and you need to remove four bolts and the plastic shield for the rear inner CV boots.
Fill plug on the front diff is behind the RF brake rotor. Be careful not to oil your brakes while filling it.
You will want a lube pump with a small hose or a syringe with a hose.
DT
Old Mar 22, 2006 | 10:53 PM
EasyQuader's Avatar
On the diffs the drain and fill plugs are a little hard to find but that won't be for a while along with the transfer case. I don't plan on doing any more than flewids, filters. greese, and brakes. Maybe a spark plug. Seems to be a lot like the new cars, it runs or it don't. If it don't, you take it in. Got a spare chipped key today. I recomend every body get one before you need one.
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
DMIMAGE
ATV Expeditions
Sep 20, 2015 06:56 AM
rgjackson
Sep 17, 2015 11:21 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
