belt deflection easy to check?
Old Mar 22, 2006 | 05:25 PM
redbarnbrute's Avatar
Default belt deflection easy to check?
i lost my manual and was needing to check the belt. i hear its pretty easy. how is it done? thanks
Old Mar 22, 2006 | 06:55 PM
alwaysride's Avatar
easy, put a strait edge from the top of the belt and push down in the middle. YOu should apply about 13 pounds of pressure but you can just press down hard measure the slack. My 360s slack is around 22-27 mm. It might be different with you 650. Check out nyrocs site if you want better instructions. www.atv.dnsalias.com
Old Mar 22, 2006 | 07:15 PM
Hayashi's Avatar
The BD spec on '05 BF650 is also 22 - 27 mm at 13 lbs of force applied in the middle. I usually set at the lower side of spec so that the adjustment can last longer. Just make sure ATV doesn't creep at the idle rpm.
Old Mar 23, 2006 | 09:19 AM
thanks, i appreciate the info
slowgsxr97
Mar 18, 2022 03:40 AM
user493
Aug 13, 2015 12:54 PM
southbayman
Jul 24, 2015 09:30 AM
trouttracker
Jul 20, 2015 11:54 AM
timster911
Jul 13, 2015 01:57 PM
