700sp white bros exhaust tuning HELP
Old Mar 24, 2006 | 08:46 AM
endeduphere's Avatar
Default 700sp white bros exhaust tuning HELP
Does anyone know how to tune the white bros exhust with the discs?? I put one on my stock 700 and it really almost seems to have less power... HELP!!
Also, just a heads up for yall, When installing a lift kit make sure to loosen the castle nut on the outer axle to allow the axle to slide in as you drop the shock. This will keep the joint together and save you alot of trouble...
Old Mar 24, 2006 | 09:07 AM
SPORTSMAN70003's Avatar
How many disc are you running? The more disc you run the more air flow it will have.
Old Mar 24, 2006 | 09:41 AM
I'm running all of them right now. I think it's 6 or 7 discks maybe? Should I take some out and try it?
Old Mar 24, 2006 | 09:48 AM
6 to 8 disc is what I see most people run. I'm running 10 right now. Have you done a plug check to see if its running lean or rich?
Old Mar 24, 2006 | 09:52 AM
Rustybronco's Avatar
Where are you ordering more disks?
Old Mar 24, 2006 | 10:02 AM
Have not done a plug check yet, I think I'll do that today. If it's rich should I add or take away discs??
Old Mar 24, 2006 | 01:10 PM
If its rich you need to add discs.
I'm not sure where to buy the extra disc mine came with 12.
Bonzhonda300ex
Sep 17, 2015 10:44 AM
bvolks
Sep 13, 2015 12:57 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
