Washing your quad
Old Mar 24, 2006 | 10:23 PM
v2rider's Avatar
Default Washing your quad
Is there anything to be cautious of on the new V2's when washing them? And can they be pressure washed in a regular car wash, with the soapy water? Thanks for any replies
Old Mar 24, 2006 | 10:55 PM
Ductape's Avatar
Most machine manuals say "do not". Most people I know do it anyway- never heard of a problem. Just use common sense and keep the nozzle away from u-joints, seals, etc.
DT
Old Mar 25, 2006 | 01:25 AM
weez440's Avatar
i use a pressure washer all the time on mine i blow everything off. the only thing i would say to be cautious of is to make sure you don't hit the decals at an angle. these machines were designed and sealed for water and mud so a quick wash won't affect them. and go ahead and use the soapy water.
Old Mar 25, 2006 | 04:11 AM
luvthemud's Avatar
i pressure wash mine all the time just be careful. i usually make sure that the seat is off. they will rip easy when blasted with almost 3000 psi. trust me i found out the hard way, OOPS
Old Mar 25, 2006 | 09:09 AM
v2rider's Avatar
Thanx guys. Im taking it up today to wash it.
Old Mar 25, 2006 | 10:14 AM
Hoopie's Avatar
your best bet is to go buy a preasure washer at home depot thats about 100 bucks. There only about 1700psi and the psi is adjustable with sprayer so you can use even less pressure on the sensitive areas. the car wash is only 3000 psi and can cause damage to any seals on the atv. its worth the investement that will pay off quickly
Old Mar 27, 2006 | 08:51 PM
kaptap's Avatar
As Hoopie says, Home Depot has pressure washers cheap. I bought the a 1300 PSI from them for $49 and it works really well. It has an adjustable nozzle so you can fan out the spray for the decals and seat. I've blwon stickers off and stuck them right back on without any problem.
Old Mar 27, 2006 | 09:12 PM
bubba123's Avatar
The little electric 1300 psi ones are the preferred method for cleaning ATVs.
Old Mar 30, 2006 | 11:00 AM
OneWolf's Avatar
You guys and your fancy pressure washers...I just use a hose and a couple rags...oh fun...
- OneWolf
Old Mar 30, 2006 | 08:17 PM
v2rider's Avatar
- OneWolf
How do you get in the small areas? Like shocks, radiator, and those areas with dried on mud, and dirt that you cant reach?
