Warrior Pull Start Q?
Old Mar 25, 2006 | 10:41 AM
JCJBanshee's Avatar
Default Warrior Pull Start Q?
Does a 93 Warrior need a good starter clutch for a pull start to work.
The starter cutch went out and I would like to just put a pull start on it.
THANKS!
Old Mar 25, 2006 | 11:57 AM
recon99's Avatar
I think the pull start is completely independent of the electric start system, so yes you should be able to use it with a bad starter clutch. It would be a good idea to check with a dealer/powersports shop before you buy the parts though, there could be something i'm not thinking of right now.
Old Mar 25, 2006 | 01:08 PM
maddmudder13's Avatar
well the pull start designed for the warrior only lasts a very short time. when my starter went out i just pull started it and eventually the pull starter broke, its desighned for emergancies only not meant to be used all the time. but now much starter clutch went out and now i fixed that but running into ignition problems because i was desprite to ride and push started it alot. so my advice to you is to wait and buy a starter clutch. save money in the long run
Old Mar 26, 2006 | 12:36 PM
JCJBanshee's Avatar
I think I will go ahead with the pull start because Im sellin the bike anyways.
Dammar
Nov 14, 2015 07:41 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
