starting problem lt250r (CARB ?)
Old Mar 26, 2006 | 09:24 PM
LT250Rens's Avatar
Default starting problem lt250r (CARB ?)
I just rebuilt my 85 lt250r, I had the cylinder bored out 60 over.
I put it all back together and it started right up, ran good for about 30 seconds then died.
note that it has been in pieces for about 5 years.
It sounds like there is no fuel making it to the cylinder.
I am no good with carborators.
I have good sprk and good compresion and it will fire when i pour a capfull of fuel straight in the cylinder. I can barley feel my leg from kicking so much!!
I also would like to know what is a good combination of aftermarket parts that i could get to see the best performance out of my quad
what works for you guys
Do i need to re-jet my stock carb because i bored it out 60 over.
Old Mar 27, 2006 | 12:45 AM
gassrx's Avatar
is the fuel running out the petcok, is there fuel in the bowl . the float might have stuck or crud got it to one of the carb ports .
Old Mar 27, 2006 | 12:48 AM
gassrx's Avatar
i would port it for $ 200 and a good paul turner pipe works well
Old Mar 27, 2006 | 12:51 AM
Scooter86's Avatar
Knows Old ATV Questions!
If it has set for 5 years, clean the carb all out, and make sure the floats aren't sticking. Buy a manual if you aren't comfy with the carb, but the stocker is a pretty simple unit. There are a few small parts though. It may be beneficial to use a digital camera and document how things are supposed to go back together. Have you checked to see if fuel flows to the carb?
Old Mar 27, 2006 | 10:08 AM
LT250Rens's Avatar
yeah, there is an vapor lock from the pet **** down to the carb, but when i take the fuel line off it flows freely so there is nothing wrong with the pet ****
dnm48
Jun 14, 2015 10:11 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
