400L On Alcohol
Just finished up with the mods on the 440EX. Now what?
I've got a '97 400 Sport (with some mods) and would like to run alcohol. I sanddrag and want the most hp I can squeeze out of this machine. I know I'll need a carb, flush tank, clutch kit, higher compression piston and alcohol just to mention a few. Does anyone have their atv set up for alcohol? I need some pointers such as what manufacturers produce the best results for alcohol. I'm planning to do the most of the mods myself so any input would be greatly appreciated.
'99 440EX
'97 400L Sport .02 Wiesco, lightened flywheel, Delta V-Force, ported and a DG pipe.
'99 440EX
I see your in St. Louis. Look up the number to Midwest Sports Center (Farmington, MO.). The mechanic there, Jason, has such a machine. A mutual friend of ours has a '00 TB running alky too! I'd give you the number, but am at school now.
The flush system isn't too difficult to do. I've got all the parts for my '99. Jason and Roy use FTZ carbs (38TMX). I bought a CT39PWK alky carb, but have decided to try the FTZ so I draw from there set-up's. So when I get the FTZ carb I'll make the switch, hopefully buy summer.
Y2KB4K@Hotmail.com
Y2KB4K@Hotmail.com
