686????
Old Mar 28, 2006 | 12:08 AM
beaner660's Avatar
Default 686????
Hey guys,
I need a little help here. Thinking about making my raptor into a 686, Is it worth it or not ?
Will I notice a big diffrence in power? Should I go with race gas or stick to pump gas?
Old Mar 28, 2006 | 01:11 PM
wennison's Avatar
Default 686????
I've got an 04 raptor sent off to LRD to get turned into a 686. I'm also changing a lil bit more than the motor though, so that maybe i can get more of that HP to the ground. I'm expecting it back the end of this week sometime i believe. It'll probably take me a week or so after that to get it into shape. I won't forget about you though, and i'll reply for sure.. Until then.......
Old Mar 28, 2006 | 03:01 PM
UBETRUN's Avatar
Default 686????
Raptors love compression and a strong 686 will run with most big bores. With a good build, you will feel more power from a 686 than you felt with a pipe, filter, and jet kit on the stocker. If you can get race gas or alky and it won't break your budget, I'd go with high compression (12.5:1+). The more power you add, the more stuff will need upgraded to handle it.
Old Mar 28, 2006 | 03:34 PM
CaptBags's Avatar
Default 686????
Mine made a huge difference. It actually Doubled the power from a stock # of 33HP to over 60!!! If standing up on the pegs doing 50+ in forth gear and, just laying on the throttle (no Clutch) and, blowing a wheelie across a sand dune is a good measure of feeling the difference - that is what you can do!
Old Mar 29, 2006 | 01:12 AM
beaner660's Avatar
Default 686????
Hey guys thanks for the info. Hope to get my raptor going pretty soon
Old Mar 30, 2006 | 09:20 PM
fordplay2's Avatar
Default 686????
Man i would definitely do the 686. I just got mine done last week and i cannot belive the difference it made. Well thats also with the exhaust, and ported head. If you do get it dont forget about the rod. I am going to little sahara this weekend. The dyno is going to be my first stop.
Old Mar 31, 2006 | 03:45 AM
kicka180's Avatar
Default 686????
670 11:5:1 compression forged pistons new valves new cam ct exhaust k&n intake, unmodified intakebox mixed 91octane +100cotance fuel =57hp [img]i/expressions/face-icon-small-smile.gif[/img] worry free about having a broken crank may not be the fastest but it is realiable...
Old Mar 31, 2006 | 04:28 AM
bassetboy55's Avatar
Default 686????
fordplay you're pretty close to me. Alot of my buddies reside in plano.
Old Apr 2, 2006 | 09:08 PM
fordplay2's Avatar
Default 686????
maybe we will all have to go ride sometime, you might even know some of us. Never know....
