Calling for HIGHTOWER!!!
Old Mar 28, 2006 | 09:52 PM
albabomb's Avatar
Default Calling for HIGHTOWER!!!
Hey I know Hightower is the man with the TM45's. So, hopefully hightower is reading this.....I just received my brand new TM45 from ondunes.com. I was under the impression that the carb would be tuned for my DS upon ordering, but I guess they only do that for the Lectrons. So, I wasn't planning for a carb puzzle. Here is what I know....It is brand new and they already added the pumper accessory. So here is my setup:
2000 DS650 (obviously)
UniTwin air filter
Portmatched intake for a TM45
Big Gun Rev Box
HPR Open End Cap
Elevation: 1000-3000' ASL
I do not know if the jet that comes in the TM45 is the right one to use or not, please help I know nothing about tuning carbs and I thought it was going to be done for me upon arrival!!! WHAT DO I DO TO GET IT RUNNING PERFECT???
Old Mar 28, 2006 | 10:17 PM
shmee's Avatar
hightower does a nice job, he did it the same day he got mine. nice.
Old Mar 28, 2006 | 10:33 PM
FatHolly's Avatar
I've read some of the threads on all the stuff he does to the TM45. My suggestion is to cut him a break (so he doesn't have to type a book) and do a search for TM45 with Hightower as the author. You should be able to find everything. Good luck!
Old Mar 29, 2006 | 02:15 AM
albabomb's Avatar
good idea, i will do a search
Old Mar 29, 2006 | 03:13 AM
albabomb's Avatar
Okay I did a search and found lots of useful info, but I was wondering if anyone can help in selection of jets to start out with. I have no idea what jets are in it now or what squirter. I have a ported intake, open air box, HRP end cap and big gun rev box. What jets and squirter should I order from RWR??? Please Help
Old Mar 29, 2006 | 07:14 AM
yjacket2001's Avatar
Trial and error adjust. Your are going to have to know how eventually without asking someone. Everyone is different. No 2 are the exact same per config and environment.
Old Mar 29, 2006 | 01:38 PM
Goodsound's Avatar
Set a New OEM chassis 4 stroke national record on his OMW DS855 - 3.93 !
#50 pump nozzle and probably a 155 main and the clip on the needle moved to the second from the top notch so the needle moves down. Clip moves up so the needle moves down.
Make sure that the pump nozzle is squirting on the needle. When I got mine it was pointed of to the side.
Old Mar 29, 2006 | 06:43 PM
albabomb's Avatar
Okay, I installed the pump accessory. I switched out the pilot jet from a #40 to a #25 which came in the kit. Also, I switched out the squirter #70 to a #50 which also came with the kit. I only got (1) Main Jet which is a #150. Is this going to work out ok??
Old Mar 29, 2006 | 07:32 PM
Goodsound's Avatar
should be okay. Mikuni jets are all the same and most dealers sell them.
Old Mar 29, 2006 | 10:56 PM
MrMeaner's Avatar
Awe just take out the pilot and put in a 300 or 310 and fill the tank with methanol. That thing will scream. It will run on alky without a main also
Customer Service #1
May 15, 2020 08:46 AM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
toonces
Sep 9, 2015 03:28 PM
black_thunder
Sep 6, 2015 04:41 PM
