yahama terrapro
Old Mar 29, 2006 | 02:00 AM
rocky1974's Avatar
Default yahama terrapro
hi all does anyone know anything about a terrapro like what is top speed on it is there a governor on it if so how to take it off of it so i get more speed
Old Mar 29, 2006 | 12:06 PM
jad1dad's Avatar
I have one. It is a true utility ATV. It has a lot of torque and is geared very low. Speedo reads up to 50, but I have been wary of this due to the rpm's at high speed. It is heavy with a dry weight of 597 lbs without any of the PTO driven attachments which are heavy as well. It also has a manual locking rear diff and will not run in high gear when possitive traction is not on. I enjoy mine with the 42" rough cut more and 30" tiller. The PTO will not operate in high gears either.
Old Mar 30, 2006 | 12:10 AM
nailzscott's Avatar
Sorry to jump subjects, but you are the only 2 people I have found that know anything about the terrapro. I am looking into buying one from a local tractor dealer who took it in trade. It has a problem that I was hoping one of you might be able to comment about. It's about the clutch. You can put the atv in gear without pulling in the clutch lever. In fact, when you pull the lever all of the way in, then the atv will start to move. I would appreciate any help or guidance you can offer. The dealer selling the unit may let me take it for a few hours to see if I can get the problem adjusted out. I was hoping that I would not have to take off the cover over the clutch, but if I do, do you know if that is a big task? Thanks
Old Mar 30, 2006 | 02:32 AM
Darthlarryboy's Avatar
My dad has one. Top speed 42 mph. For work it's great, for play I'll take my Suzuki. We call it the terrible-pro.
Old Mar 30, 2006 | 03:17 PM
jad1dad's Avatar
Sorry, I don't know anything about the internal mechanics at all. I do know that the internal clutches are wet clutches. It could be possible that if there is no oil (MOTO 20w40) that the clutches could be stuck.
Old Mar 31, 2006 | 01:12 AM
nailzscott's Avatar
Thanks for the input. I will be checking it out this weekend.
Old Sep 23, 2020 | 12:10 PM
Amanda DelaRosa's Avatar
did anyone ever figure out the clutch
NewGuy2481
Oct 6, 2015 05:54 AM
scott1988
Aug 18, 2015 08:44 AM
DML
Jun 30, 2012 08:32 AM
TrxR
Apr 21, 2010 11:57 AM
flogger
Utility ATVs
12
Jan 1, 2009 06:09 PM
