Yamaha Raptor 660 Exhaust tip
Old Mar 31, 2006 | 01:42 PM
dreamMACHINE's Avatar
Default Yamaha Raptor 660 Exhaust tip
hya, well on the end of the stock exhaust is a samller pipe, one which i believe comes out, and will improve performance and sound. ??????is this right?
Old Mar 31, 2006 | 05:35 PM
RaptorRookie's Avatar
I'm guessing that you are talking about the spark arrestor. Go ahead and take that thing out. It will make your bike sound better, and it might free up a little bit of power but probably not enough to notice. There is an 8mm bolt on the bottom. Just take that out then twist out the S.A. You might need some pliers or somethin to get it out as it might be kinda tight. Its not a huge change, so rejetting really isn't necesary. Just take it out and go.
-Brandon
Old Apr 1, 2006 | 04:37 AM
kk a wil do, i tried that yesterday but it was reali tight,. luks like a should just pull harder on it.thanks
Old Apr 1, 2006 | 10:46 AM
fasterufool's Avatar
it will give alittle bit of power, but mostly sound. good luck!!!!
Old Apr 2, 2006 | 03:21 AM
ive tried it, but i cant pull it out. i used some pooor plyers and fencing plyers. both gripped it but i couldn't pull it out, i was just pulling the quad. i then stopd the quad from moving and still can't get it out. ive sprayed it with wd40, im stuck as i dont think it wants to come out. [ i did all this with the small bolt out] lol
Old Apr 2, 2006 | 04:35 AM
2FAST4U69's Avatar
I forget how I did mine when I first got it, but I think I removed the whole end-cap and then pulled the SA...
black_thunder
Jul 22, 2015 06:01 PM
black_thunder
Jul 12, 2015 11:04 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
