works shocks
Old Nov 16, 2000 | 01:18 AM
aggromoose's Avatar
are the works stadium shocks zero preload. if they are how do they compare to the others. they are way cheaper
Old Nov 16, 2000 | 08:50 AM
jeepin's Avatar
NO they are not.I was sitting to a guy next to me at the starting gate last race that had them.He sent them to tcs and had the zps thing done.HE said it was like night and day.I am not sure if he said tcs but I think it was.
86 trx 250r wiseco .020 piston,boyesen reeds,porting by p.m.s,FMF gold series fatty pipe,power core 2 silencer,dg alloy series nerfs,jd performance +2 A-arms,durablue eliminator 2+2 adjustable width axle,durablue posi loc axle nut,LSR bearing carrier,nac's casesaver,uni filter,whhite bro's white power shocks with adjustable res's all the way around,braking brake pads,fastline braided steel brake lines,PEP easy pull clutch perch and lever,motion pro clutch cable,pro design kill switch,18/11/8 holeshot mx's on mitchell .190's,21/7/10 holeshots on ITP wide off-set .190's
www.angelfire.com/me3/fmf86trx250r
www.angelfire.com/me4/muddyR/pics
Old Nov 16, 2000 | 03:38 PM
DS650DAVE's Avatar
Is zero preload a better way to have ashock set-up for hard riding & jumping quads?
Old Nov 18, 2000 | 06:35 PM
wcy2k400ex's Avatar
DS650DAVE,
From everything that I've heard and read, ZPS is great for racing. I was told that it keeps the wheels on the ground better.
Old Nov 20, 2000 | 01:28 AM
hakmazter's Avatar
From what I understand the stadium series are in fact Works version ZPS shocks. Now, what I do know is that ZPS style shocks have 1 real purpose and that is for the quad to sit lower at rest. This means that you are lower to the ground for cornering. The ZPS are stiffer even though they have full travel when jumping, they compress stiffer once you get past the rest point so they do not bottom out. I spent alot of time on the phone with Works and I love them. I had them set up so that I can swap 2 springs and then they are zps height. A stock 400ex Works shock has 10.5" travel and it is supposed to sag 3", with the zps, it sags 4-5"
Old Nov 21, 2000 | 02:24 AM
aggromoose's Avatar
Are you saying that you can go grom triples to zps. do they have the same valving and it sounds like the stadiums are rock hard.
hugemoth
Jul 20, 2020 03:28 AM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
bikedad3
Jul 2, 2015 02:15 AM
