05 Rancher AT Flashes ESP on Display
Old Apr 3, 2006 | 01:46 PM
RancherATCrazy's Avatar
Default 05 Rancher AT Flashes ESP on Display
OK this is my last hope before I take it into the shop. My Rancher AT flashes ESP instead of displaying the N, D, R (Neutral) (Drive) (Reverse). It starts fine, when put into Reverse I just get a bunch of sputtering and jerking. In Drive it will move forward but I can't shift out of 1st Gear and the power is seriously impaired. ESP is the error code for the computer; it flashes 12 times then is solid for a few seconds. The Book says that 12 is the ECU CPU error. But I can play around in forward making sharp right and left turns shut it off then restart and every now and then it will display correctly and I can ride normally. That makes me think it has to be a short in a wire somewhere. I don't want to take it to the shop and have them replace the CPU if it is just a wire that is loose or shorted. Any ideas?
05 Rancher AT x 2
Stone Stock
Old Apr 3, 2006 | 01:49 PM
chicano's Avatar
It is probably your angle sensor.
Old Apr 3, 2006 | 01:52 PM
Is there a way to check?
Old Apr 3, 2006 | 01:55 PM
chicano's Avatar
they say you can but i dont know how has something to do with a ohm meter but i dont know what a good one should ohm out at.
Old Apr 3, 2006 | 01:57 PM
chicano's Avatar
check your private message rancherat
Old Apr 3, 2006 | 02:08 PM
I did check your's too.
Old Apr 3, 2006 | 02:14 PM
Any other ideas?
Old Apr 3, 2006 | 02:17 PM
chicano's Avatar
check out this link
http://www.atvfrontier.com/Forums/vi...le+sensor.html
Old Apr 3, 2006 | 03:22 PM
Thanks for the link; I will definitely check out the angle sensor. How much do want for yours if mine is bad?
Old Apr 3, 2006 | 03:24 PM
chicano's Avatar
$30 + shipping
