raptor sprokets
Old Apr 4, 2006 | 08:49 PM
RaptorKid1187's Avatar
Default raptor sprokets
I was wondering if a 12 tooth front sproket is a good way to get more acceleration out of my raptor for mx or should i go lower. Rear Sproket??? And will i need a new chain or can i just tighten the stock one??
Old Apr 4, 2006 | 08:53 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
What size tires you running? and whats your current gearing.. with 22" rears 12x42 is pretty good all around on a 660.. with 20's12x40 seems to be pretty decent 12x42 fits in the stock chain and 12 by 40 also fits. i cant remember if i trie 13 42 or not.
Old Apr 4, 2006 | 09:21 PM
Raptor149's Avatar
believe it or not I ran 12/44 gearing for motocross. it was a little steep. but just dropping to a 12 up front, and keeping the rear stock would be a fair improvement for motocross. I also run 20 inch tires. but now I have bumped my gearing back up to 13 in the front and 42 in the rear. makes it a little more balanced, plus I just put in a stage 1 cam, high compression piston and new LRD pro4 exhaust.
your gearing will depend upon your other mods, i.e. exhaust, filter, tire size. but just dropping a tooth in the front helps out.
Old Apr 4, 2006 | 09:55 PM
My mods are WB E-series slip on pipe and a k&n filter. My tire size is 22 and im not sure what my current gearing is
Old Apr 5, 2006 | 11:48 PM
Fahq's Avatar
Your stock gearing should be 13 in the front right now. I dropped a tooth in the front but, it wasn't for racing. I did it because it seemed like I was downshifting into first too often. I wanted 2nd gear to be more usable in tighter areas. It will make a difference out of the hole though. Makes 2nd gear holeshots a lot easier. It is a cheap part and easy enough to put in. Give it a shot. If you don't like it, switch back.
Old Apr 6, 2006 | 09:49 AM
hixquadguy's Avatar
hey man i got a 2002 660 raptor and i have the same problem you do, i felt like i had to down shift into 1st way to much! when you dropped a tooth in the front did it improve the acceleration alot?? And how much did it take off the top end
Old Apr 6, 2006 | 07:01 PM
Fahq's Avatar
I walk away from my buddies stock 660r. It isn't until 5th gear that he starts to gain on me. I couldn't really say what exactly I lost top end. I have that thing pinned so rarely, the smaller front sprocket made sense.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
