06 450r Dyno Jet Kit HELP!!
I just bought a new 06 450r. i was wondering what to do now. i have a full dmc afterburner exhaust, k & n filter, and that's it. the directions told me to put the needle at the 4th position, did that. then start with a 128 main jet. did that, still way to lean, now i'm up to a 136 or 138, there is only one bigger jet size left in the kit, and i think that is an 140. what would you guys suggest i do next. oh yeah and the air/fuel screw is turned out 2.5 times like the directions recommended. want to go riding this sunday, thanks for the help in advance. the spark plug ceramic is starting to turn a pinkish color, and i run 93 octane.
Do you have a vented air box or running no airbox lid? If so you'd be around a 180 If you lid is on and your only mod is a pipe you should be 120 to 130(max)
This is for an 04 to 05,Not sure if the same hols true for the 06
/Jon
The quad runs great. it doesn't backfire or anything when i let of the gas, and the power is right there. I checked the plug last night, it's not near as white as it was. I checked the top end this time, by goin full speed full throttle and then killing the motor. the plug looks decient, it's not near as white, and is a real lite tanish color, personaly i would like to have it a little bit darker. how much gain would i get with the air box lid off? and what would that do to the jetting i have now.? thanks again for the help.
Cantbuytime
Aug 17, 2015 06:33 PM
Aug 5, 2015 02:10 AM
