raptor axle bearing removal
Old Apr 5, 2006 | 06:16 PM
dangeranger's Avatar
Default raptor axle bearing removal
yea so i broke a chain adjuster bolt and need to get the bearing carriers out so that i can see where im drilling through this hole......got the axle out just fine but not having any luck with two cast pieces on either side of the bearing housing....how the hell do you get these off!!!! i know you have to get the spacer to separate from the bearings....any help would be great!!
Old Apr 5, 2006 | 08:51 PM
fordplay2's Avatar
Well here is how i did it... Im not saying to do it this way but i did it with what i had. A hammer, and a lot of cussing..... Really, i just kept banging on the side where the brake rotor was till it came off. Sorry but i dont have any advice on how to do it right. All i can say is that it sucks.
Old Apr 6, 2006 | 01:19 AM
yea thats what i hear....ive been hitting that side with a 4lb sledge and it wont budge....i need a bigger hammer
Old Apr 6, 2006 | 05:40 PM
SmokieDaBear's Avatar
I know exactly what your talking about. I end up breaking my chain tensioner bolt too & had to change the bearings. After alot of beating & drilling I end up buying another carrier off of ebay. It can be done, it just takes time.
Advise: I put a big chisel & sprayed WD40 in the housing to get the old bearings out.
Good Luck
Old Apr 6, 2006 | 06:35 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
use a plastic mallet and a piece of wood to rap on it till the 2 sides seperate
throw the carrier on top of a woodstove or in the oven for a bit,,,,the aluminum will expand and the bearing should come out a bit easier
Old Apr 6, 2006 | 08:26 PM
fordplay2's Avatar
Im not trying to be an a$$, im just making sure. Did you take out the two bolts that hold it together? Im not saying that you didnt just saying, cause i have done some really stupid things before. (Dont ask it would be a long list of things.)
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
Rider252
Jul 6, 2015 03:37 PM
