Grizzley Oil Change
Old Apr 6, 2006 | 07:32 PM
Ragnar's Avatar
Default Grizzley Oil Change
I recently changed oil on my Grizzley. My owners manual stated that I needed 2.11 quarts of oil. I added the oil and then I started it to let it fill the filter. I then let it set for a while and then check the oil. When I checked the oil the dipstick showed way overful. Has this happened to anyone else? Before I drained the oil, I started the machine to warm up the oil so it would drain better. Any info would be helpful.
Old Apr 6, 2006 | 07:37 PM
OGGYDOGGY's Avatar
I really dont like the dry sump deal , I would rather just check the oil before I start it.I dont know what happened in your situation. The .11 is only like an 1/8 th of a qrt.
Old Apr 21, 2006 | 10:51 PM
RonK's Avatar
I just got a new 2006 660 and it was about 1/2 quart overfull from the factory...I had about 1.4 hours on it when I checked the level. I siphoned about 13 ounces out of it through the oil fill hole. It is still somewhat overfull. I may remove more oil later.
The level on the dipstick NOT SCREWED IN was 1/2 inch above the Max level at the crosshatched area.
Old Apr 21, 2006 | 11:13 PM
Ragnar's Avatar
That is about how full my dipstick had showed.
Old Apr 22, 2006 | 12:30 AM
RonK's Avatar
Did you remove some oil?
Something as simple as checking the oil should not be so confusing. The manual clearly shows the oil should be in the crosshatched area. Why would Yahmaha specify 2.11 quarts and have the level 1/2 inch above the mark they show in the manual. The oil drains back down in less than 5 minutes.
This is ridiculous.
Old Apr 22, 2006 | 01:41 AM
thor440's Avatar
I thought I was using oil because your supposed to start it and check. When I checked the oil prior to starting, it read full. Ran it, and it wasn't even on the dipstick. What we supposed to do, count to 100 before checking?
Old Apr 22, 2006 | 02:02 AM
RonK's Avatar
The reasoning is likely that some oil should be in the upper oil galley and that is why they recommend to check it "after a few minutes" after stopping. However, on my Grizz, most of the warm oil returned to the sump in 1 minute and almost all of it in 3 minutes and all of it (back to the cold checking mark) in 5 minutes. So, I will be checking it cold before I start and then after about 5-10 minutes of riding. Or check it at the end of the day's ride and be ready for the next day. In brief: check it often!
Old Apr 22, 2006 | 02:28 AM
Hebs's Avatar
It doesn't come with oil from the factory... Your dealer over filled it...
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
