Keeping it cool 2 Not overheat
Old Apr 24, 2006 | 05:00 PM
Boz900rr's Avatar
Default Keeping it cool 2 Not overheat
Looking for all ideas to help keeps the machine running as cool as possible.
1.) Engine Ice.
2.) Wrapping the header.
?????? All suggestion are welcome???????
I have heard that wrapping the header will cause premature rusting.
I have heard the argument that $30 for Engine Ice is not worth the 50 Deg. differences. Is the
50 deg difference enough to not kill the machine on a hot day?
The history behind this is mud in the radiator fine which is causing the machine to overheat either I need to find a deflection system that works or I need to make other changes like mentioned above. If you have any suggestions or know where to get some sort of deflection system? Any help is greatly appreciated.
Old Apr 24, 2006 | 05:11 PM
DuneRider650's Avatar
I ride a little here and there......
Engine ice is worth it and does work for me....you could use that get some radiator shrouds so you get more air....put a manual rad fan switch on your machines dash....not sure what ya could do about the mud...ive never had that happen to me. There are larger radiators avaliable and larger volume water pumps also but even with this if mud plugs ur rad its still going to heat up fast.
mtdewmn
Jan 19, 2017 12:13 PM
clsharky
Jul 13, 2015 02:07 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
