wet sportsman 500
Old Nov 18, 2000 | 11:13 PM
stick3's Avatar
i ran my 2000 sportsman 500 in creek and completey submurged it what all do i need to check for water
damage???? checked oil in motor and trans. looks ok. got it granked seems fine.
Old Nov 23, 2000 | 11:12 PM
waynaferd's Avatar
I dunno 'bout your sportsman, but my 00 TBlazer has a drain plug under the recoil to drain the starter. I'd grease it to push the water outa the bearings and bushings, and maybe check the cv shaft boots, in case they're full of water.
Old Nov 24, 2000 | 05:43 PM
Xpedtion4254x4's Avatar
This is what you need to do? I ride in a lot of water and i sunk my atv before the best thing to do to avoide any problems is. Chang all of you oil even gear case and tranni oil. Because if you got in water that deep then water is probly in the air box and engine. So change all of the oil trust me. Then clean out air filter and get any water out of air box. Drain carburater very good. Also drain belts and recoil start. Also Drain muffler open clean plug on mufler (details in owner manual) Aftr that you good to go!!!
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
