Help with Dinli 90, won't start
Old May 1, 2006 | 11:51 AM
sssduane's Avatar
Default Help with Dinli 90, won't start
Out riding this weekend and my sons 90 died. It cranks over fine, with starter and kick start, pull the plug and it sparks when placed on the head. Plled the carb and cleaned it up, didn't look dirty inside. It fires once in a while but sounds like it might be firing out of time. Is there a chance the timing could be off. I haven't looked under the stator cover yet but was wondering what I should look at. I'm going to pull the carb again and spray it down real good and blow air through it.
It is modiifed with a Kiehen 24mm, carb, KOSO pipe and intake.
Old May 1, 2006 | 01:11 PM
oldyeller's Avatar
Sounds like you might have some broken reeds.
Old May 2, 2006 | 10:51 AM
Wandell's Avatar
I don't know. Ours has always started fine. However a couple of weeks ago we went to ride and had a starting problems. It fired up fine and we took off. Made it about 50 or 100 feet and it died. I tried to start it forever before it restarted. It's done fine ever since. I've read that the auto choke on the carb can cause problems sometimes. Maybe that's it.
Old May 2, 2006 | 11:07 AM
sssduane's Avatar
Pulled the reeds and they look fine.
THe auto choke is gone, its got a Kiehen 24mm carb on it now.
I'm gonna grab a can of carb cleaner, soak it and blow it out really well.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
