o6 z400 suspention question
Old May 3, 2006 | 01:07 AM
allstardj's Avatar
Default o6 z400 suspention question
want to soften front end have already soften stock shock as much as possible looking to try different shock springs
am on budget can anyone help
Old May 3, 2006 | 03:59 PM
Z40005BR's Avatar
did you mess w/ the preload?
Old May 3, 2006 | 10:19 PM
allstardj's Avatar
just put the screw above spring to the top
how do i adjust preload if that is not it
new to all of this stuff need help understanding
Old May 8, 2006 | 05:24 AM
s9195's Avatar
400 ex shocks will mount in the Z perfectly and I found are alot softer.... you can find used ones on ebay pretty cheap.
Old May 10, 2006 | 02:36 AM
mucky's Avatar
doesnt the 06 have rezzys on the shocks?if so try to readjust the settings to a softer compression, if the springs are to stiff then loosen them but make sure they are adjusted the same but remember if you loosen the spring tension the bike will sit lower to the ground
and your preload is how high the bike sits with nobody on it. the more you tighten the springs the higher the bike is and the stiffer the suspension
but you dont want them to loose or your shocks wont work properly and you will bottom out the bike and thats no good either
Old May 11, 2006 | 01:52 AM
allstardj's Avatar
thanks for the info how far should i adjust the rezzys from stock setting
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
