KFX 80 Oily Mess
Old May 4, 2006 | 05:21 PM
BartKFX's Avatar
Default KFX 80 Oily Mess
My son's 2003 KFX 80 started leaking oil all over the back of the engine shroud.
It seemed to be coming from the spark plug rubber gasket that had popped off. I took the plastic engine shroud off and found a lot of oil all over the cylinder, head, and case, is this normal? It would make sense that if it was normal that the fan would be blowing oil out of the spark plug hole if the rubber gasket came loose. The ATV runs just fine.
Old Feb 17, 2007 | 07:54 PM
Insaneindmembrane's Avatar
Could be a pin hole or small crack in the oil tank?
ltrmc02
Aug 22, 2021 02:34 PM
salixair
Nov 3, 2015 08:25 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
