Tire pressure and performance...Outy 800
Old May 14, 2006 | 12:29 PM
Pastor's Avatar
Default Tire pressure and performance...Outy 800
I have been on cloud nine riding this thing...and have learned already that this thing is a beast. At riding at speeds over 35...I felt a slight "twitch" in the steering. Nothing major, I just expected total smoothness. When I got home, I checked the tire pressure with the gauge that they generouslly provided...all the tires were set at about 6.5 with one being over 7, ( I am sure just a mistake from the dealer). I brought all of them dowm to 6 lbs. and alot of the "twitch" went a way. However, there is still a little wiggle there. I looked at the manual and it states 4.5 max.- 4.0 min. And so, I come to the pro's here on my home site to ask you...does pressure have that much to do with handling? I am going to drop the pressure on all tires to 4.5. What do you think?
Old May 15, 2006 | 01:00 AM
Pastor's Avatar
Somebody out there has got to have info. on this...
Old May 15, 2006 | 02:28 AM
travelor's Avatar
what did you find out after lowering pressure?
Old May 15, 2006 | 01:21 PM
truckguy's Avatar
I have tried everything to get rid of my shimmy out of my front end! Asked dealer if he had a tire balancer at his store and he told me he does not balance quad tires????? I am new to this, I just figured you balanced those tires too (i am in automotive) , there are wheel weights stuck on the inside of my wheels, you do balance these tires do you not???? I am 3.5 hours away from brp dealer, so i tried balancing them myself but can't get the balancer set up right to do these tires. I did notice ALOT of tire wobble on those carlisles (while on the balancer), if these where automotive tires I would say that the tires have seperated. I just don't know what i should expect from these bike tires. Hopefully someone can help???? I can get my bike to go over 70 mph but the damn thing shakes way too much.
Old May 15, 2006 | 02:23 PM
chirochris's Avatar
i run 4lbs all around and have no shaking even at high speeds, that i notice anyway..
Old May 16, 2006 | 10:31 AM
jimcb's Avatar
everybody says you can't balance atv tires ,then why do they come with weights on them from the factory someone must make a balancer for them
Old May 16, 2006 | 12:39 PM
jimcb's Avatar
come on some one has to have some in put on this help
Old May 16, 2006 | 08:27 PM
05dsrider's Avatar
yes the fronts do need to be properly balanced for that shake to go away and this only happened on a few models
Old May 16, 2006 | 10:16 PM
kawiyowee's Avatar
You shouldn't be getting a 'twitch' or is it a shimmy(?) at any speed. I have had tire pressures from 4 - 6.5, don't feel any shimmy. Take it to him, tell you want it fixed, and you can be really non-sociable if poked in your shimmy.
Old May 17, 2006 | 01:10 PM
truckguy's Avatar
It's a shimmy 4 sure, only felt in the handlebars, and only when the bike hits 62mph + It gets worse all the way up to top speed. I can go faster when I am doubling someone. Must be because i am taking weight off the front end.
On another note, does anybody know the toe in adjustments on this bike. The dealer has told me they should both be at 0 ???
