Predator Out Of Alignment???
Old May 17, 2006 | 09:09 PM
NevadaCat's Avatar
Default Predator Out Of Alignment???
My Predator recently had a front flat. The tire shop used a goo to fix it, kinda like the green stuff but supposedly better. Now when I get up to about 35 or 40 MPH the frontend starts to shake back and forth. Any suggestions?? Can I put goo in the other front to balance it? Did I mount the wheel improperly? I used to work in a tire shop so I think I know how to do it. Does the red Thing that goes on before the wheel need to be put on a certain way? Any suggestions would be appreciated! Can I put balancing stuff in the tires? I believe this can be done with big truck tires.
Thanks Bret
Old May 17, 2006 | 10:57 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
I would remove the two front tires and weigh them to see if you really have that much of a change in the two wheels!!!A little bit of "GOO" should not make the atv shake that much at 35-40 mMPH.
Old May 17, 2006 | 10:59 PM
I for got to say the "GOO" could have dried and caused a large lump to settle in the bottom when it was still!!!
Old May 18, 2006 | 05:45 AM
ScramblerXLE's Avatar
sounds a lot like that's what happenned.
Old May 21, 2006 | 03:16 PM
NevadaCat's Avatar
Thanks for the replies! I should probably just buy a new tire. Are there any problems with the green Stuff? It stays liquid until a puncture right? I'll get some for all four tires.
Bret
Old May 23, 2006 | 01:49 AM
actually as a rule of thumb i'd try to just stay away from any sealing compound entirely. With a car it's fine, but something so light as a quad is very easily thrown around by any sort of balance issue with a tire. If one of your tires goes flat, an innertube will fix it fine, i'd just try to stay away from any of those additives... my $.02
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Canamaniac!
Sep 15, 2015 06:19 PM
Elkaholic
Sep 6, 2015 02:44 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
