roller secondary still available?
can u still get a team secondary
i am thinking of adding another mod
but not ready to go into the motor
would a carb be usless with just a pipe
would a team secondary give me a noticable gain?
thanks to all replies
yes you can still get the team clutch. although they dicontinued the TAS98 and the TAS 99 is the only one available.
you will notice the team clutch. set up right with the right spring/helix for your riding style, youll love it. no more changing out buttons.
X
X
hey
how did you come up with your set up
i'd hope to keep the same top speed
with more snap down low&mid
i some times ride tight trails with rocks
so i need low speed driveability
is the install fairly simple
thanks for the quick info.
install is very quick. out with the old, in with the new. simple bolt in. if you want recommendations for a good setup. call HPD, or rittercylceracing. they will give you the best advice for you. and set it up how you want it.
X
X
Steeldon
Sep 9, 2015 09:38 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
