Electrical problem???? I think.
Old May 22, 2006 | 10:17 AM
BAJAXPIMPN's Avatar
Default Electrical problem???? I think.
I was at a buddies house riding this weekend. He just bought 20 acres and we're designing a track on. Well as we were making his tracks "signature" table top jump I was testing the the lengths of what we needed for distance. So, I'm landing on the flats at 60 feet. On the third pass I landed and the the dash came loose and the DS just shut down. I looked at the dashes top bolt and it ripped through the plastic were it attaches. The two bottom rubber mounts were fine. Then I noticed that no lights are on. I turn the key to on then off, to on then off....nothing. I looked under the dash and everything seems to be attached and conntected properly. Is there something else I can check before I have to take it in?
Thanks.
Old May 22, 2006 | 12:16 PM
SW2steve77's Avatar
check your fuses under your seat. The main fuse will be on your right if you would be sitting on it. It should be 25 amp. Double check all connections like battery and check to see if you cut any wires or looked like it got bent from something from the fall.
Old May 22, 2006 | 04:08 PM
BAJAXPIMPN's Avatar
Bump
SW2steve77, thanks I've checked the fuses and there fine. So if anybody's had the same thing happen to them or got anything else to look at let me know.
Thanks.
Old May 22, 2006 | 09:06 PM
chirochris's Avatar
i got nothing for you but would love to see pics of the jump and you jumpin it
Old May 23, 2006 | 08:16 AM
TheChosenOne's Avatar
that little gold thing at the back that the main power wire connects to from the battrery. the rectifier or somethinalongthemlines. It is 5 AM... but seriously, same ting happened to me as well. drivin along, then bam nthin whatsoever. except in this case you were jumpin...mo matter... but i bet your problem lies there.
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
coldnorthpol
Jul 14, 2015 11:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
