Longer wheel studs Sportsman 335
Old Nov 22, 2000 | 01:37 PM
Glen's Avatar
I know this question was asked recently, but nobody had a solution, so I'll ask again. Does anybody know of a source to purchase longer wheel studs for a Polaris Sportsman 335? I trashed my stock wheels riding some real rocky terrain in Virginia. I purchased a set of Douglas .190 Red Label wheels. The fronts fit fine, but the rear studs are coming up a little short due to the thicker center section of the Douglas wheels. The lug nuts are only threaded half way before they bottom out. I was thinking about popping out the studs and using stainless grade 8 bolts to mount my rear wheels. Anybody run in to this problem? -Glen
Old Nov 22, 2000 | 01:58 PM
bowtiepu's Avatar
im not sure if its the same as my quad but the rear studs are only bolts held in with clips..remove them and take them to your local hardware store for longer bolts,problem solved?
Old Nov 22, 2000 | 02:27 PM
Glen's Avatar
bowtiepu, Thanks for the info. My studs are regular pressed in studs. I noticed the Scramblers are like your quad with bolts and clips. I think I just pop out the studs and use bolts. Durablue wheel spacers are like that also. -Glen
Old Nov 22, 2000 | 02:41 PM
bowtiepu's Avatar
take one out and take it to your local auto parts store and see if they can match it up to one..i know some foreign cars have smaller studs
Old Nov 22, 2000 | 10:49 PM
Farmr123's Avatar
Hot Seat sells longer front studs...rear, well, I just don't know for sure, but that's the first place that pops int my mind.
Old Nov 23, 2000 | 07:18 AM
Glen's Avatar
Thanks for the info. I'll give Hot Seat a call. If not I'll replace the studs with bolts. -Glen
Jmuddin284
Jan 19, 2026 07:16 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Shifts
14
Jul 13, 2015 08:41 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
