warrior clutch plzzzzzz help
Old May 22, 2006 | 10:05 PM
Lukemysta66's Avatar
Default warrior clutch plzzzzzz help
i cant get my clutch to work on a 1989 warrior. the pressure plate pulls in, but there is no movement in the clutch. do you think i need a new plate kit?thx
Old May 22, 2006 | 10:08 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
make sure the revser lever is al lthe way forward and you are putting the quad in gear... lol
Old May 22, 2006 | 10:11 PM
no them are all set, i dont nkow wut it is. i put an old clutch in too, and it still didnt work.
Old May 22, 2006 | 10:12 PM
recon99's Avatar
I don't know what you mean. How do you know the pressure plate is getting pushed in? You can't see it when it's put together, and it won't operate with the cover off.
Old May 22, 2006 | 10:16 PM
i can feel the pressure plate pull in when i pull the lever. but i put it in gear,pull it in and it doesnt work,i push the bike forward and it doesnt roll it stops cuz it is not grabbing..do you know wut i mean?
Old May 22, 2006 | 10:24 PM
recon99's Avatar
I'm not sure. Maybe you didn't get the timing marks lined up right? I dunno, i'd just take it apart and double check everything against the diagrams in the service manual.
Old May 22, 2006 | 10:26 PM
oh no there is timing marks on this!! i never knew clutches had it. i dont have manual, is there anyway you can just tell me how to do it. is it the arrow on the clutch? where does the arrow have to point?
Old May 22, 2006 | 10:32 PM
nice warrior by the way[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 22, 2006 | 10:43 PM
recon99's Avatar
It's been a while since I did mine, so it's going to be hard for me to explain it, but I uploaded a service manual if you want to take a look at it for yourself and see what you can figure out: http://members.toast.net/rikoster/atv/a6s5e71sda.pdf
Old May 23, 2006 | 10:13 PM
recon99 thx a bunch. i went bak through everything and double checked. all it was was the pressure plate needed adjusting. thx a lot for the book,can u get one for any atv?if so can u give me the site u got if from plzz.
