Bomb 800 - No start
Old May 24, 2006 | 02:22 PM
truckguy's Avatar
Default Bomb 800 - No start
Old May 24, 2006 | 02:25 PM
truckguy's Avatar
Hmmm - i will try that again
Left ignition on for aprox 8 hrs, have done this before - cycled ignition and vroom bike starts back up.
Not this time, the only thing I get is a fuel pump cycling on everytime I turn key/on off switch on or when I hit the starter button.
Other then that nothing, no lights, no dash lights, anybody have any ideas??
Old May 24, 2006 | 02:29 PM
truckguy's Avatar
Yes, the battery is good, i took it out and topped up the charge just to be sure
Old May 24, 2006 | 11:25 PM
maxxedouty's Avatar
Old May 24, 2006 | 11:55 PM
truckguy's Avatar
In neutral/park when starter is engaged all that happens is the fuel pump turns on.
In gear nothing happens unless brake is applied, then all that happens is the fuel pump turns on.
No lights , no starter engagement, no dash lights, nothing happens except the fuel pump turns on.
Old May 25, 2006 | 01:15 AM
truckguy's Avatar
I'm a little red faced!!!!!
Never visually check fuses, always check them with a meter or light lol
The fuse appeared to be perfect but.... it was not!
Problem fixed
Old May 25, 2006 | 08:24 PM
maxxedouty's Avatar
Thats good you located a bad fuse, but why should it blow just because you left the key in the on position?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
hot_shoe_cv
Oct 13, 1999 02:16 PM
