400EX Can and XR400 Cam--Difference?
some told me that with the following a 400 can do 88 mph
-slip on pipe
-K&N filter
-correct jetting
-porting
-3 angle valve work
-xr 400 cam
-Polishing the inside of where the exhaust somes out both in the headpipes and in the engine to match exactly
-and with correct gearing
BS or not?
-slip on pipe
-K&N filter
-correct jetting
-porting
-3 angle valve work
-xr 400 cam
BS or not?
Hmm, the XR cam is differnt as Honda even stated so when the EX came out. I vividly rember honda stating that only the pistion, Head and cylinder are XR copys and everything else is beefed up for the EX. I know my friends EX has alot more torque than my XR400R does.
Well, according to my 400ex service manual, the valve timing at 1mm lift (.040", where on most car cams it's measured at .050") in intake opens at 5°BTDC, closes 40°ABDC, and the exhaust opens at 40°BBDC, closes 5°ATDC. This gives a duration of 225 intake and 225 exhaust at .040" lift (add 180 + opening + closing time). I can't find the valve lift ANYWHERE in the manual, but if your specs are correct for the XR cam, then it is indeed a little bigger cam (more duration) than the 400EX has.
Also, if you want specs on the WB cams, check out this web page (stated valve timings are at .040" lift on there as well):
http://www.motojoe.com/atv_pages/whi...engine_atv.htm
UPDATE ON THE CAM QUESTION!!!! Through my own research I have found that the XR and EX cams are different. The duration of the EX cam is 225 degrees on intake and exhaust. The duration of the XR cam is 232.5 degrees on intake and 232 degrees on the exhaust. I will find out about the lift tomorrow. So, to all of you who were wondering about this, here is the answer.
