Tire sizes
Old Nov 23, 2000 | 02:27 AM
Sharpe1's Avatar
I have a '97 Scrambler 400 w/RCR mods and am looking to replace the badly balded tires that came on it. Do the tire sizes really make a difference in how the 4 wheel drive works. I've heard you have to keep the 1 inch difference between front and rear for it to work properly. If this is the case would a smaller back tire than stock cause the front hubs to lock in sooner or make no difference at all?
I am looking to run some Pure Sports Bandit XC's (21x7x10 and 20x10x10). I don't mind the loss of ground clearance (I think it would probably feel better in the turns with it a little lower) but don't want to screw up the 4 wheel drive engagement.
Old Nov 25, 2000 | 04:20 PM
waynaferd's Avatar
The smaller tires spin faster, that's all. Which means the gears could lock right up and not move, or blow all to hell. 1inch (1/2inch, actually) is nothing to worry about, since there could be that much variance in a set of tires any way, and since I presume you'll be on dirt and not tar in 4 wheel drive, the tires can slip easy,anyway. In fact, some mud runners(pick-ups) run a size or two smaller in front to keep them spinning faster and keep the front up on top of the mud.
Old Nov 25, 2000 | 06:51 PM
waynaferd's Avatar
Oh, smaller tires are like having lower gears, so if you get to concerned, change your rear sprocket. (I have no idea to what size)
Old Nov 26, 2000 | 01:47 AM
Sharpe1's Avatar
Thanx for the reply. I have a better picture of what I'm dealing with now, I think. I thought there might be some adverse effect on the 4 wheel drive engagement if not using the same stock tire size ratio. The only thing that might change, if I understand you correctly, is the speed in which the four wheel drive actually engages the front hubs. Smaller rear tires - faster engagement . The smaller tires on the rear and the increased rpm's of the rear tire would replicate the wheel spin of a larger tire, right?
Thanx for the help and let me know how close I am to understanding this.
Old Nov 26, 2000 | 03:37 AM
01Grizzly's Avatar
Your over all tire size should be the same front to rear, regardless of the rim size. Unless you have the R&P gears set up to operate at different rates of rotation from front to rear!
Rick
Bratman2
Aug 6, 2022 01:42 AM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
rcappie4
Jul 18, 2015 07:51 AM
