250 Trailboss, no low end power
Old May 29, 2006 | 10:58 PM
Herm's Avatar
Default 250 Trailboss, no low end power
When I pull the throttle my TB spits and sputters at first and then starts to run fine (it will go 45mph). This isn't very noticeable when kids are riding on the dirt roads (no load), but if you start up a steep hill from a stop it can not get revved up enough to get enough power to go up.
I plan to put a new plug in and run some Seafoam through it this weekend, but not very confident this will fix.
Any ideas what else I should try?
Old May 30, 2006 | 12:30 AM
HondaSlayer's Avatar
make sure your air filter is clean, if it is then i would try going down a size on the pilot jet
Old May 30, 2006 | 01:53 AM
Polaris500HO4x4's Avatar
very true, i had a similar problem and it turned out to be a dirty air filter
Old May 30, 2006 | 11:05 PM
Herm's Avatar
Thanks, but I cleaned the air filter already with no luck. So much for the easy fix.
Is there any adjustment on the carb for the low end?
MeadowlarkFarm
Nov 27, 2019 08:40 PM
bvolks
Sep 13, 2015 12:57 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Myronh
Sep 8, 2015 11:27 AM
byronman
Sep 6, 2015 06:34 PM
