PLEASE HELP!!! YFZ 450????'s
Old May 31, 2006 | 02:07 PM
Kevin1022's Avatar
Default PLEASE HELP!!! YFZ 450????'s
O.K. here is my problem. I just purchased a 06 yfz 450 and come to realize that the type of riding that i do i need some more ground clearence. i would like to know if getting bigger rear tires will hurt the bike. Making the bike slower isn't that important b/c it is fast enough. please let me know if there are any suggestions with tires or other options! Thanks
Old May 31, 2006 | 04:36 PM
GITRDUN's Avatar
Larger tires will give you more ground clearance and will take away a little acceleration. But it might also make you a little more top heavy.
Old May 31, 2006 | 04:51 PM
bberck's Avatar
It wont hurt the bike it will just change the gearing some. You will lose a little down low but gain top speed. This can be ballanced back by changing a sproket size so is no big deal if dont like the new gearing. It will change the handling some but I dont think you will notice much from 1 size change. The 450 has such a low center of gravity it wont make it top heavy
Old May 31, 2006 | 05:00 PM
Kevin1022's Avatar
Thanks, in your opinion what is the largest (tallest) tire you would go with.
Old May 31, 2006 | 05:12 PM
bberck's Avatar
22 on back and 23 on front
