CR250 Head on a R?
Old Nov 24, 2000 | 12:29 AM
DaveyR's Avatar
Has anyone had any experience with using a CR250 head on a TRX250R? Not the head gasket, but head itself..Does the coolant lines connect the same as a R head...Any feedback would be great!
Old Nov 24, 2000 | 11:18 AM
MX265X's Avatar
it was done in a magazine once they had to block off the powervalve and do case work. only a special piston could be used. they said it had great power but it was too expensive and labor-taking for anyone but a pro to do. it you want an aftermarket cylinder go w/ the pro-x cylinder kits. they come w/ everything and it goes on just like a normal 250R (except 330 and up the case needs machined) they come in a 250, 295, 310, 330, and 410 kits and everyone says that add so much power but anyway that my just $0.02
Old Nov 24, 2000 | 12:18 PM
DaveyR's Avatar
MX265, it sounds like your talking about a CR cylinder..I'm just talking about bolting on a CR Head on a stock R jug??
Old Nov 24, 2000 | 12:38 PM
MX265X's Avatar
oh i was sorry i dont think the head will either my friend has a 250r and a milled CR head and the water jackets are diff along with the bolt pattern but i think the head was off a 90s CR maybe a late 80s CR head would fit
Old Nov 24, 2000 | 03:30 PM
jeepin's Avatar
I t will fit.I was at a local high performance dirtbike/atv/pwc store and they had 98 cr 250r head on a 88 trx250r cylinder they said it worked fine.The bolt pattern is the same they said basicly it was the same head.
86 trx250r wiseco .020 piston,boyesen reeds,porting by p.m.s,FMF gold series fatty pipe,power core 2 silencer,DG alloy series nerfs,JD performance +2 A-arms,durablue eliminator 2+2 adjustable width axle,white bro's white power shocks with adjustable res's all the way around,Durablue posi loc axle nut,PEP easy pull clutch perch and lever,motion pro clutch cable,uni filter,braking brake pads,fastline braided steel brake lines,nac's casesaver,18/11/8 holeshot mx's on mitchell .190's,21/7/10 holeshots on ITP wide off-set .190's
www.angelfire.com/me3/fmf86trx250r
www.angelfire.com/me4/muddyR/pics
Old Nov 24, 2000 | 04:31 PM
DaveyR's Avatar
Jeepin-I've heard they do fit as well..But, did you happen to notice on the one you looked at how the coolant lines connected? I hear the CR head has 2, somewhat smaller coolant line vs the R's one? Thanks
1ArmBandit
55
Oct 14, 2015 09:03 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
