2 questions belt slip & plug in tire
Old Jun 6, 2006 | 11:34 PM
pittmanlogs's Avatar
Default 2 questions belt slip & plug in tire
I have 2 quick questions. I have noticed severe belt slippage in the bomb 800 when hittting a water hole above 15 mph. Is this normal? 2nd question, I punched a hole in my sidewall on my last trip to Rockouse. It took about 7 plugs and a can of fix-a-flat to "limp" it to a tire shop. At the shop they installed a boot and a tube. Is it safe to continue agressive riding on this tubed tire, or should I replace it? Any comments will help. Thanks
06 800 XT FOLLOW NO ONE
Old Jun 7, 2006 | 09:15 AM
44MAG's Avatar
Check your CVT cover, some have had a problem with them being warped and leaking water in.
Old Jun 7, 2006 | 02:51 PM
Thanks, I will check the cover. Any thoughts on the tube in tire?
Old Jun 7, 2006 | 05:12 PM
44MAG's Avatar
I don’t see any problems with a tube in a tire, you should be fine.
3quadbob
Sep 18, 2016 09:46 PM
Larry S
Jul 4, 2015 12:54 PM
Gator1
Oct 10, 2000 09:58 PM
Wannabee
Feb 2, 2000 10:26 AM
